[petsc-dev] Running dsymutil in GNU make build
Jed Brown
jedbrown at mcs.anl.gov
Mon Nov 4 13:34:06 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Yes both files are significant - and as far as I know - both get created
> at the same time. [this is perhaps similar to .f -> .o/.mod]
That is worse because there is no (reliable) way to determine the name
of the .mod files without running the compiler. Any given file could
produce one or many and their names need not be related to the file.
Fortran is repugnant.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131104/137174a1/attachment.sig>
