[petsc-dev] Running dsymutil in GNU make build
Satish Balay
balay at mcs.anl.gov
Mon Nov 4 13:00:41 CST 2013
On Mon, 4 Nov 2013, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > Wrt gnu compilers last I checked - fortran common blocks [requiring
> > dllexport stuff] was and issue. [perhaps gfortran doesn't have proper
> > support for it yet - don't know]
> > The other issue to fix would be gmakefile compile command. [currently
> > gcc/dll works with cmake build using --with-fc=0]
> What commands are different when linking with the GNU compilers on
> Windows? This just looks like a handful of linker flags.
> http://cygwin.com/cygwin-ug-net/dll.html
Yes - basically it creates both a .a and .dll file [so extra options
to specify these output files]
Previous discussion regarding these options wrt configure is at:
https://bitbucket.org/petsc/petsc/commits/35f77c308f25e52f9381e42e5c4c1d10058d0ecd#comment-464562
> > Wrt MS compilers - I haven't checked. [last I checked - I got bogged
> > down with cmake stuff - and didn't get a working dll]
> Can you use MS compilers to create a DLL that depends on Cygwin (as it
> must until/unless we make PETSc totally independent of posix).
If using MS compilers we don't have or want cygwin.dll in the dpenedency chain.
> > The 'fortran commom block' stuff probably works with ifort [with the
> > required preprocessor directives]. Presumably txcorp and mic-tc have
> > patches for that. The other issue is the build command to get dlls
> > with MS compilers [via gmakefile]. I think txcorp uses cmake and
> > presumably mic-tc uses MS project files..
> This because win32fe does not support the necessary options?
I'll have to check on this. [I don't know the exact options required
here even without win32fe ..]
Satish
