[petsc-dev] Running dsymutil in GNU make build
Mon Nov 4 13:20:16 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
>> http://cygwin.com/cygwin-ug-net/dll.html
> Yes - basically it creates both a .a and .dll file [so extra options
> to specify these output files]
So both files are significant and there is no way to create them
separately?  Does the single concept "shared library"/"DLL" refer to
both the .dll and the .dll.a?  Can the names have the same stem?
If so, we can specify them using pattern rules:
%.dll %.dll.a : prereqs
	recipe
Make cannot guarantee proper clean-up after failure if we don't specify
dependencies completely and accurately.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131104/228ceb34/attachment.sig>
