[petsc-dev] Making a PetSc Roll and Rocks Module
Blaise A Bourdin
bourdin at lsu.edu
Thu Jan 24 18:54:33 CST 2013
On Jan 24, 2013, at 6:37 PM, Satish Balay <balay at mcs.anl.gov>
wrote:
> On Fri, 25 Jan 2013, Blaise A Bourdin wrote:
>> the usual naming scheme is just the version number, but for petsc, most supercomputing centers use %version-%arch
>> the installer will copy the file into $MODULEPATH/petsc/%version-%arch, or the user to $HOME/.modulefiles
>> Of course, %version-%arch is a really silly name out of context. How about petsc-%version-%arch, somewhere within $PETSC_DIR/$PETSC_ARCH, or $PETSC_DIR/$PETSC_ARCH/modulefiles/%version-%arch ?
> And PETSC_ARCH has no singificance with prefix install [the
> significant text is in the prefix-path - and one doesn't have to match
> PETSC_ARCH to this significant text]
True. I actually realized that as I was hitting send
> BTW: Is the following notation ok? [google didn't help]
> prepend-path PATH /home/balay/spetsc/asterix64/bin:/home/balay/spetsc/bin
It seems to work, but
prepend-path PATH /home/balay/spetsc/bin
may be safer.
Both will break under windows, but I don't think it is a problem, really
Blaise
> I have some fixes [except for the modfile name] which I can push.
> thanks,
> Satish
>> Blaise
>> On Jan 24, 2013, at 6:19 PM, Satish Balay <balay at mcs.anl.gov>
>> wrote:
>>> On Thu, 24 Jan 2013, Matthew Knepley wrote:
>>>> On Thu, Jan 24, 2013 at 3:42 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
>>>>> I am attaching a very basic module file for reference. One would need to
>>>>> update petsc_dir and petsc_arch upon deploying these, or perhaps configure
>>>>> can do it.
>>>>> I actually use this to easily switch between builds and debug / optimized
>>>>> versions
>>>> Pushed something that writes your simple module file to
>>>> lib/modules/PETSc.mod. It would now be good to get feedback
>>>> to make this the right thing.
>>> The name conflists with f90 modules. Perhaps there is a different
>>> notation for software modules?
>>> Also for prefix install we should set PETSC_ARCH=""
>>> And for inplace install - do we also add PETSC_DIR/bin to PATH?
>>> Satish
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
