[petsc-dev] Making a PetSc Roll and Rocks Module
    Satish Balay
    balay at mcs.anl.gov
    Thu Jan 24 19:11:42 CST 2013
On Fri, 25 Jan 2013, Blaise A Bourdin wrote:
> >> the usual naming scheme is just the version number, but for petsc, most supercomputing centers use %version-%arch
> >> the installer will copy the file into $MODULEPATH/petsc/%version-%arch, or the user to $HOME/.modulefiles
> >> Of course,  %version-%arch is a really silly name out of context. How about petsc-%version-%arch, somewhere within $PETSC_DIR/$PETSC_ARCH, or $PETSC_DIR/$PETSC_ARCH/modulefiles/%version-%arch ?
> > And PETSC_ARCH has no singificance with prefix install [the
> > significant text is in the prefix-path - and one doesn't have to match
> > PETSC_ARCH to this significant text]
> True. I actually realized that as I was hitting send
For now I've changed name to '%version-%arch'.
Perhaps we should provide a configure option --with-module-name=foobar
[for situations where the user can provide a prefered name]
> > BTW: Is the following notation ok? [google didn't help]
> > prepend-path PATH /home/balay/spetsc/asterix64/bin:/home/balay/spetsc/bin
> It seems to work, but
For now - I've pushed the above notation.
Satish
