[petsc-dev] Making a PetSc Roll and Rocks Module
Satish Balay
balay at mcs.anl.gov
Thu Jan 24 18:37:08 CST 2013
On Fri, 25 Jan 2013, Blaise A Bourdin wrote:
> the usual naming scheme is just the version number, but for petsc, most supercomputing centers use %version-%arch
> the installer will copy the file into $MODULEPATH/petsc/%version-%arch, or the user to $HOME/.modulefiles
> Of course, %version-%arch is a really silly name out of context. How about petsc-%version-%arch, somewhere within $PETSC_DIR/$PETSC_ARCH, or $PETSC_DIR/$PETSC_ARCH/modulefiles/%version-%arch ?
And PETSC_ARCH has no singificance with prefix install [the
significant text is in the prefix-path - and one doesn't have to match
PETSC_ARCH to this significant text]
BTW: Is the following notation ok? [google didn't help]
prepend-path PATH /home/balay/spetsc/asterix64/bin:/home/balay/spetsc/bin
I have some fixes [except for the modfile name] which I can push.
thanks,
Satish
> Blaise
> On Jan 24, 2013, at 6:19 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > On Thu, 24 Jan 2013, Matthew Knepley wrote:
> >> On Thu, Jan 24, 2013 at 3:42 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
> >>> I am attaching a very basic module file for reference. One would need to
> >>> update petsc_dir and petsc_arch upon deploying these, or perhaps configure
> >>> can do it.
> >>> I actually use this to easily switch between builds and debug / optimized
> >>> versions
> >> Pushed something that writes your simple module file to
> >> lib/modules/PETSc.mod. It would now be good to get feedback
> >> to make this the right thing.
> > The name conflists with f90 modules. Perhaps there is a different
> > notation for software modules?
> > Also for prefix install we should set PETSC_ARCH=""
> > And for inplace install - do we also add PETSC_DIR/bin to PATH?
> > Satish
