[petsc-dev] Making a PetSc Roll and Rocks Module
    Blaise A Bourdin
    bourdin at lsu.edu
    Thu Jan 24 18:26:00 CST 2013
the usual naming scheme is just the version number, but for petsc, most supercomputing centers use %version-%arch
the installer will copy the file into $MODULEPATH/petsc/%version-%arch, or the user to $HOME/.modulefiles
Of course,  %version-%arch is a really silly name out of context. How about petsc-%version-%arch, somewhere within $PETSC_DIR/$PETSC_ARCH, or $PETSC_DIR/$PETSC_ARCH/modulefiles/%version-%arch ?
Blaise
On Jan 24, 2013, at 6:19 PM, Satish Balay <balay at mcs.anl.gov>
 wrote:
> On Thu, 24 Jan 2013, Matthew Knepley wrote:
>> On Thu, Jan 24, 2013 at 3:42 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
>>> I am attaching a very basic module file for reference. One would need to
>>> update petsc_dir and petsc_arch upon deploying these, or perhaps configure
>>> can do it.
>>> I actually use this to easily switch between builds and debug / optimized
>>> versions
>> Pushed something that writes your simple module file to
>> lib/modules/PETSc.mod. It would now be good to get feedback
>> to make this the right thing.
> The name conflists with f90 modules. Perhaps there is a different
> notation for software modules?
> Also for prefix install we should set PETSC_ARCH=""
> And for inplace install - do we also add PETSC_DIR/bin to PATH?
> Satish
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
