[petsc-dev] Making a PetSc Roll and Rocks Module
Thu Jan 24 18:19:46 CST 2013
On Thu, 24 Jan 2013, Matthew Knepley wrote:
> On Thu, Jan 24, 2013 at 3:42 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
> >  I am attaching a very basic module file for reference. One would need to
> > update petsc_dir and petsc_arch upon deploying these, or perhaps configure
> > can do it.
> > I actually use this to easily switch between builds and debug / optimized
> > versions
> Pushed something that writes your simple module file to
> lib/modules/PETSc.mod. It would now be good to get feedback
> to make this the right thing.
The name conflists with f90 modules. Perhaps there is a different
notation for software modules?
Also for prefix install we should set PETSC_ARCH=""
And for inplace install - do we also add PETSC_DIR/bin to PATH?
Satish
