[petsc-dev] Removed functions in MPI 3
Jed Brown
jedbrown at mcs.anl.gov
Tue Jan 22 16:48:44 CST 2013
On Tue, Jan 22, 2013 at 4:39 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Carefully fiddling with my local sources prior to the commit... I don't
> know of a way to test the backwards-macros other than inspecting the
> preprocessed code...
> Oh, and Barry's macro proposal was right (I forgot that this assumed an
> update of sources already)
Use your Open MPI build and put
#define OMPI_WANT_MPI_INTERFACE_WARNING
before including mpi.h. They put in __attribute((deprecated)) so you'll get
warnings for all the old usage. Test that the new version still works with
MPI-1 by building with --with-mpi=0 (or download an illicit copy of MPICH1).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130122/a55269fc/attachment.html>
