[petsc-dev] Removed functions in MPI 3
Karl Rupp rupp at mcs.anl.gov
Tue Jan 22 16:39:35 CST 2013
Hi Matt,
 >              Since there was a lack of consensus on alternatives, I
applied
>              Matt's Right Way here:
>         https://bitbucket.org/petsc/____petsc-dev/commits/____fabf60c7d012db5a109255579665b5____c2
>         <https://bitbucket.org/petsc/__petsc-dev/commits/__fabf60c7d012db5a109255579665b5__c2>
>         <https://bitbucket.org/petsc/petsc-dev/commits/fabf60c7d012db5a109255579665b5c2>>
>         https://bitbucket.org/petsc/____buildsystem/commits/____355293e9e4e0588644168f629930b5____66
>         <https://bitbucket.org/petsc/__buildsystem/commits/__355293e9e4e0588644168f629930b5__66>
>         <https://bitbucket.org/petsc/buildsystem/commits/355293e9e4e0588644168f629930b566>>
>              This is mostly done to ensure that we don't forget about
>         the initial
>              goal of fixing the issue. Cleaner/more unified solutions to the
>              problem are still welcome...
>         This is almost there. I will have BuildSystem write the define
>         directly
>         like Barry suggested.
>     Okay, thanks! Just make sure you set up the macros in the right way
>     (Barry accidentally interchanged the old and the new versions in his
>     email).
> How are you testing this?
Carefully fiddling with my local sources prior to the commit... I don't
know of a way to test the backwards-macros other than inspecting the
preprocessed code...
Oh, and Barry's macro proposal was right (I forgot that this assumed an
update of sources already)
Best regards,
Karli
