[petsc-dev] Removed functions in MPI 3
Matthew Knepley
knepley at gmail.com
Thu Jan 24 13:52:08 CST 2013
On Tue, Jan 22, 2013 at 4:48 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Jan 22, 2013 at 4:39 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
>> Carefully fiddling with my local sources prior to the commit... I don't
>> know of a way to test the backwards-macros other than inspecting the
>> preprocessed code...
>> Oh, and Barry's macro proposal was right (I forgot that this assumed an
>> update of sources already)
> Use your Open MPI build and put
> #define OMPI_WANT_MPI_INTERFACE_WARNING
> before including mpi.h. They put in __attribute((deprecated)) so you'll
> get warnings for all the old usage. Test that the new version still works
> with MPI-1 by building with --with-mpi=0 (or download an illicit copy of
> MPICH1).
This is pushed. I checked with MPIUNI and MPICH and it worked. I can't
bring myself to build with OpenMPI.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130124/88c161b7/attachment.html>
