[petsc-dev] Removed functions in MPI 3
    Matthew Knepley
    knepley at gmail.com
    Tue Jan 22 16:24:13 CST 2013
On Tue, Jan 22, 2013 at 4:12 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi Matt,
>      Since there was a lack of consensus on alternatives, I applied
>>     Matt's Right Way here:
>>     https://bitbucket.org/petsc/__**petsc-dev/commits/__**
>> fabf60c7d012db5a109255579665b5**__c2<https://bitbucket.org/petsc/__petsc-dev/commits/__fabf60c7d012db5a109255579665b5__c2>
>>     <https://bitbucket.org/petsc/**petsc-dev/commits/**
>> fabf60c7d012db5a109255579665b5**c2<https://bitbucket.org/petsc/petsc-dev/commits/fabf60c7d012db5a109255579665b5c2>
>>     https://bitbucket.org/petsc/__**buildsystem/commits/__**
>> 355293e9e4e0588644168f629930b5**__66<https://bitbucket.org/petsc/__buildsystem/commits/__355293e9e4e0588644168f629930b5__66>
>>     <https://bitbucket.org/petsc/**buildsystem/commits/**
>> 355293e9e4e0588644168f629930b5**66<https://bitbucket.org/petsc/buildsystem/commits/355293e9e4e0588644168f629930b566>
>>     This is mostly done to ensure that we don't forget about the initial
>>     goal of fixing the issue. Cleaner/more unified solutions to the
>>     problem are still welcome...
>> This is almost there. I will have BuildSystem write the define directly
>> like Barry suggested.
> Okay, thanks! Just make sure you set up the macros in the right way (Barry
> accidentally interchanged the old and the new versions in his email).
How are you testing this?
  Matt
> Best regards,
> Karli
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130122/e03f3523/attachment.html>
