[petsc-dev] Style Guide: How to format single-line if/for/while-blocks?
Karl Rupp
rupp at mcs.anl.gov
Tue Jan 22 13:28:35 CST 2013
Hi Jed,
> So, so I will continue quickly along the following path:
> -> Bring sources to a clean state
> -> Provide simple and robust guard scripts (pre-commit/pre-push)
> Note that pre-commit cannot be run on a user's machine without their
> assistance (configuring hgrc). (Doing so would be a huge security
> vulnerability.)
Yes, I'm aware of that. Since we have to update hgrc for the BuildSystem
anyway, it's 'just another line'.
If we reject the commit server-side, the author will
> have to edit their history (requires enabling an extension unless it's
> the last commit). Since it's a hassle to go back and fix the history,
> hopefully it will teach developers to enable the commit hooks.
Eventually we can come up with a hook that aggregates multiple commits,
i.e. the user only needs to add a follow-up commit fixing the violation
rather than fiddling with the history.
> -> Configure uncrustify such that it reports violations (nightly)
> -> Document user-specific uncrustify configs
> Until someone finds a way to do this with Hg, I think this last point
> would only be meaningful to git users.
Albeit not ideal, I think it's reasonable to
- either wait for a similar way of doing that with Mercurial, or
- use gitifyhg
for users who insist on using custom non-PETSc-style. This is a fairly
low hurdle compared to what you get for it.
Best regards,
Karli
