[petsc-dev] Style Guide: How to format single-line if/for/while-blocks?
Jed Brown
jedbrown at mcs.anl.gov
Tue Jan 22 14:02:35 CST 2013
On Tue, Jan 22, 2013 at 1:28 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Yes, I'm aware of that. Since we have to update hgrc for the BuildSystem
> anyway, it's 'just another line'.
Yeah, well, I still think it's rude for a build script to mess with the
user's private repository configuration. We only get away with it because
beginners don't know better and experts usually configure their system so
it doesn't run (e.g., by pulling BuildSystem themselves) or know that it's
running.
> If we reject the commit server-side, the author will
>> have to edit their history (requires enabling an extension unless it's
>> the last commit). Since it's a hassle to go back and fix the history,
>> hopefully it will teach developers to enable the commit hooks.
> Eventually we can come up with a hook that aggregates multiple commits,
> i.e. the user only needs to add a follow-up commit fixing the violation
> rather than fiddling with the history.
This is horrible because the aggregating commit will touch lots of
irrelevant lines. If it does more than change whitespace, git/hg can't even
give us a diff that looks past that rearrangement. It's important for every
commit making it into the repository to be formatted consistently.
> -> Configure uncrustify such that it reports violations (nightly)
>> -> Document user-specific uncrustify configs
>> Until someone finds a way to do this with Hg, I think this last point
>> would only be meaningful to git users.
> Albeit not ideal, I think it's reasonable to
> - either wait for a similar way of doing that with Mercurial, or
> - use gitifyhg
> for users who insist on using custom non-PETSc-style. This is a fairly low
> hurdle compared to what you get for it.
Queue Matt screaming about how he'll never (a) use git OR (b) put a space
after 'for'.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130122/1bc62230/attachment.html>
