[petsc-dev] Coding style and its violations...
Jed Brown
jedbrown at mcs.anl.gov
Thu Jan 17 17:39:19 CST 2013
On Thu, Jan 17, 2013 at 5:34 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Yes, for just stripping out comments without starting preprocessor magic
> this seems to be a viable way:
> http://stackoverflow.com/**questions/2394017/remove-**
> comments-from-c-c-code<http://stackoverflow.com/questions/2394017/remove-comments-from-c-c-code>
> Since stripping C comments from sources is far from trivial in the general
> case, I pretty much like the approach of simply using gcc for that.
Cool, that's good to know.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130117/6b8cf490/attachment.html>
