[petsc-dev] example broken for a while src/mat/examples/tests/ex104.c
Tue Jan 15 16:30:01 CST 2013
  This example has been broken for a while, did it ever work?
0a1,25
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Object is in wrong state!
> [0]PETSC ERROR: C != D!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Development HG revision: 34c1b366b0f8fabca0e1f952a026363f6ea75443  HG Date: Fri Jan 11 14:02:35 2013 -0600
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./ex104 on a arch-gnu named Barrys-MacBook-Pro.local by barrysmith Tue Jan 15 16:28:10 2013
> [0]PETSC ERROR: Libraries linked from /Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> [0]PETSC ERROR: Configure run at Fri Jan 11 21:09:18 2013
> [0]PETSC ERROR: Configure options --download-blacs --download-cmake --download-fftw --download-fiat --download-generator --download-hypre --download-libyaml --download-metis --download-ml --download-mpich --download-mumps --download-parmetis --download-ptscotch --download-scalapack --download-scientificpython --download-superlu --download-superlu_dist --download-triangle --download-yaml --with-afterimage --with-ams-dir=/Users/barrysmith/Src/ams-dev --with-java --with-openmp --with-pthreadclasses --with-server --with-shared-libraries PETSC_ARCH=arch-gnu --download-sowing
> [0]PETSC ERROR: main() line 74 in src/mat/examples/tests/ex104.c
> application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
> [cli_0]: aborting job:
