[petsc-dev] Coding style and its violations...
Barry Smith
bsmith at mcs.anl.gov
Tue Jan 15 15:48:56 CST 2013
On Jan 15, 2013, at 3:43 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi,
>> Some projects (e.g., moose) reject a noncompliant push. The
>> committer can then rewrite the patch locally before it is
>> published and resubmit.
>> IIRC, this is done server-side, but with a DVCS, that's too late (or
>> causes the "pusher" a lot more trouble). Hg and Git both support
>> client-side commit hooks.
>> The upside is that setting the check server-side you ensure it is run.
>> Otherwise you have to rely on each committer to configure it locally.
> Yeah, that was my intention. We can certainly provide instructions to set a commit-hook, but it's the user's responsibility to set this up. The only way to enforce compliance is on the server's side. And yes, even though we are using a DVCS, we have a central repository where finally all commits are fed to.
Right, sorry my mistake initially referring to the push. We provide an appropriate commit-hook people can use and then on push we reject (automatically) noncompliant code (i.e. code that hasn't been passed through the commit hook properly)?
Barry
> Best regards,
> Karli
