[petsc-dev] Coding style and its violations...
    Karl Rupp
    rupp at mcs.anl.gov
    Tue Jan 15 15:54:34 CST 2013
>>>         Some projects (e.g., moose) reject a noncompliant push.  The
>>>         committer can then rewrite the patch locally before it is
>>>         published and resubmit.
>>>     IIRC, this is done server-side, but with a DVCS, that's too late (or
>>>     causes the "pusher" a lot more trouble). Hg and Git both support
>>>     client-side commit hooks.
>>> The upside is that setting the check server-side you ensure it is run.
>>>   Otherwise you have to rely on each committer to configure it locally.
>> Yeah, that was my intention. We can certainly provide instructions to set a commit-hook, but it's the user's responsibility to set this up. The only way to enforce compliance is on the server's side. And yes, even though we are using a DVCS, we have a central repository where finally all commits are fed to.
>    Right, sorry my mistake initially referring to the push. We provide an appropriate commit-hook people can use and then on push we reject (automatically) noncompliant code (i.e. code that hasn't been passed through the commit hook properly)?
Yes, that appears most reasonable to me.
An automatic update of .hg/hgrc as Jed proposed is certainly an option.
I prefer opt-in over opt-out in this case.
Best regards,
Karli
