[petsc-dev] Coding style and its violations...
Dmitry Karpeev karpeev at mcs.anl.gov
Tue Jan 15 14:55:54 CST 2013
On Tue, Jan 15, 2013 at 2:51 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Jan 15, 2013 at 2:47 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Yes. Jed is too in love with Git to ever do this so you have to.
> What does this have to do with choice of VCS? They all support commit
> hooks.
>> > - Add nightly tests on the source tree. We can compare the output of a
>> properly configured uncrustify against the existing source files and
>> complain on a mismatch.
>>      The problem is that uncrustify is exactly the PETSc style so we
>> can't do that comparison automatically. Otherwise we would just run
>> uncrustify on all pushes.
> The sha1 changes when you change whitespace so it'll be messy to do on
> push (rather than on commit) because the pusher will need to zap their old
> version of the patches. (Note that the push might happen after merging in
> release-3.3, for example, so it gets nasty.)
Some projects (e.g., moose) reject a noncompliant push.  The committer can
then rewrite the patch locally before it is published and resubmit.
Dmitry.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130115/3cfccfcc/attachment.html>
