[petsc-dev] PETSc goes Doxygen!?
Jed Brown
jedbrown at mcs.anl.gov
Sun Jan 13 19:24:17 CST 2013
On Sun, Jan 13, 2013 at 5:30 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi,
> > Any way to strip the ierr = and CHKERRQ(ierr); from all the html
> versions of the source code. I find it cluttering and ugly.
> It doesn't work 'directly' as Doxygen currently does not apply filters to
> examples. The remedy is an additional copy&conversion step, i.e. something
> comparable to
> $> cp -R src/ tmp/
> $> find tmp/*/examples/tutorials/*.c | xargs sed -i 's/ierr = //g'
> $> find tmp/*/examples/tutorials/*.c | xargs sed -i 's/CHKERRQ(ierr);//g'
> This seems to do the job:
> http://krupp.iue.tuwien.ac.at/**petsc-doxygen/dm_2examples_**
> 2tutorials_2ex1_8c-example.**html<http://krupp.iue.tuwien.ac.at/petsc-doxygen/dm_2examples_2tutorials_2ex1_8c-example.html>
Doxygen doesn't apply the input filter for examples? That's lame, but
hopefully they can add an option to do that.
> @Jed: I've disabled the EXTRACT_ALL switch, now only documentation for
> commented entities is generated. Static functions should not be shown
> anyway (EXTRACT_PRIVATE = NO). I could also set EXCLUDE_PATTERN to
> something like *_Private and/or *_Internal. Do you know a better
> systematic way of identifying internal stuff without touching sources?
PETSc doesn't have any public functions containing underscores (only enums
and feature macros). Can you exclude functions that way? From the docs, it
looks like EXCLUDE_PATTERNS excludes entire files while EXCLUDE_SYMBOLS has
all symbols lumped together. Sadly, that seems to only take a glob rather
than a regex, and it lumps all symbol types together.
Would strict symbol visibility help limit which symbols doxygen considers
to be public? There is a --with-visibility flag that will avoid exporting
the internal symbols.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130113/6b418f80/attachment.html>
