[petsc-dev] PETSc goes Doxygen!?
    Karl Rupp
    rupp at mcs.anl.gov
    Sun Jan 13 22:08:44 CST 2013
> Doxygen doesn't apply the input filter for examples? That's lame, but
> hopefully they can add an option to do that.
I have tried multiple filter scripts but none of them was applied to the
examples. The 'examples' module does not seem to experience a lot of
love anyway, see e.g.
   https://bugzilla.gnome.org/show_bug.cgi?id=149253
(yes, Barry, that ticket is from 2004...)
>     @Jed: I've disabled the EXTRACT_ALL switch, now only documentation
>     for commented entities is generated. Static functions should not be
>     shown anyway (EXTRACT_PRIVATE = NO). I could also set
>     EXCLUDE_PATTERN to something like  *_Private and/or *_Internal. Do
>     you know a better systematic way of identifying internal stuff
>     without touching sources?
> PETSc doesn't have any public functions containing underscores (only
> enums and feature macros). Can you exclude functions that way? From the
> docs, it looks like EXCLUDE_PATTERNS excludes entire files while
> EXCLUDE_SYMBOLS has all symbols lumped together. Sadly, that seems to
> only take a glob rather than a regex, and it lumps all symbol types
> together.
Sorry, I meant EXCLUDE_SYMBOLS rather than EXCLUDE_PATTERN. Even though
it does not allow regex, the wildcards should be sufficient.
> Would strict symbol visibility help limit which symbols doxygen
> considers to be public? There is a --with-visibility flag that will
> avoid exporting the internal symbols.
Hmm, do you still see internal functions floating around in the doxygen
output? I think they disappeared when I turned off EXTRACT_ALL.
Best regards,
Karli
