[petsc-dev] elemental stuff still broken
Satish Balay
balay at mcs.anl.gov
Fri Dec 20 15:50:40 CST 2013
On Fri, 20 Dec 2013, Jed Brown wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
> >>> Since Jack has fixed these issues why is this still broken in
> >>> nightly tests of next?
> >> He fixed the issues in his repository, but we never told PETSc to use
> >> his new version.
> > Should we be using his repository? Should we be figuring out better
> > ways of handling updates to other software from our stuff? It is
> > not productive to have this kind of stuff happen, how can we
> > prevent it in the future?
> When he updates, we should be making a one-line commit in
> config/PETSc/packages/elemental.py to use his new version. It's not
> hard, but someone has to do it. I'm about to step onto a plane, but I
> can do it when I land.
Sorry didn't update this before. Will test and commit the fix.
BTW: this is in jed/elemental-int64 branch [which hasn't been merged
to master yet]
And I'll also remove all self.download usage when self.gitcommit [as
this is inconsistant code]
[And I need to complete balay/giturl-fixes so that tarball urls are
automatically constructed from giturls - for usage without git]
Satish
> I don't want to "automatically" use the most recent version because then
> PETSc builds will break when he uses a new language feature or changes
> an interface, and we won't be able to reliably rewind to an old state.
