[petsc-dev] elemental stuff still broken
    Karl Rupp
    rupp at mcs.anl.gov
    Fri Dec 20 14:29:37 CST 2013
Hey,
>> When he updates, we should be making a one-line commit in
>> config/PETSc/packages/elemental.py to use his new version.
>     How do we know that “we should be making a one-line commit in elemental.py”? And who should make the “one line commit”?
>     Anything that relies on “should” is not a good system,
Ideally it is Jack who pushes the one-line change whenever he publishes
a new release. Maybe he's also willing to run a separate branch on
GitHub (i.e. something like PETSc's maint) which we can use in
master/next. Our maint would need a stable release version, though...
However, I'm not sure whether this is worth the additional maintenance
troubles. With some branch tracking it becomes harder for *us* to
determine which elemental version was used in a build if user problems
show up.
Best regards,
Karli
