[petsc-dev] elemental stuff still broken
Fri Dec 20 16:30:52 CST 2013
On Fri, 20 Dec 2013, Satish Balay wrote:
> On Fri, 20 Dec 2013, Jed Brown wrote:
> > Barry Smith <bsmith at mcs.anl.gov> writes:
> > > On Dec 20, 2013, at 1:45 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > >>>  Since Jack has fixed these issues why is this still broken in
> > >>>  nightly tests of next?
> > >> He fixed the issues in his repository, but we never told PETSc to use
> > >> his new version.
> > >    Should we be using his repository? Should we be figuring out better
> > >    ways of handling updates to other software from our stuff? It is
> > >    not productive to have this kind of stuff happen, how can we
> > >    prevent it in the future?
> > When he updates, we should be making a one-line commit in
> > config/PETSc/packages/elemental.py to use his new version.  It's not
> > hard, but someone has to do it.  I'm about to step onto a plane, but I
> > can do it when I land.
> Sorry didn't update this before. Will test and commit the fix.
I tried using latest elemental commit - and got errors. Then I noticed
the fix was the following - so retried with this snapshot - and I still get build errors.
https://github.com/elemental/Elemental/commit/08daf5a157bd3addc8b1a6649f99e2f2e65ec03d
Attaching the elemental build log. This build is with clang:
clang version 3.3 (tags/RELEASE_33/final)
Target: x86_64-unknown-linux-gnu
Thread model: posix
Satish
> BTW: this is in jed/elemental-int64 branch [which hasn't been merged
> to master yet]
> And I'll also remove all self.download usage when self.gitcommit [as
> this is inconsistant code]
> [And I need to complete balay/giturl-fixes so that tarball urls are
> automatically constructed from giturls - for usage without git]
> Satish
> > I don't want to "automatically" use the most recent version because then
> > PETSc builds will break when he uses a new language feature or changes
> > an interface, and we won't be able to reliably rewind to an old state.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131220/c1a53f71/attachment.ksh>
