[petsc-dev] BG hang still broken in petsc-maint!
Wed Dec 18 17:28:59 CST 2013
On Dec 18, 2013, at 3:17 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>  We’ve had this discussion before and wasted too much time on it. On
>>  the BG just don’t allow the damn loading of options for files for
>>  large runs, say greater than 128 nodes
> If we're going to ignore the files, we should generate a loud warning at
> configure time and then *always* ignore the files.  Ignoring only on
> large runs sets people up to do a small trial run and then launch their
> expensive job, only to find that it ignored their options.
   I never said “ignore” the files. I said error out if the files exist or somewhat passes a file name down.  Yes erroring out is a bit annoying but much better than hangs.
    I also question why some system calls are made on all processes but only used on one, for example
 if (!flag) {
    ierr = PetscGetHomeDirectory(pfile,PETSC_MAX_PATH_LEN-16);CHKERRQ(ierr);
    /* PetscOptionsInsertFile() does a fopen() on rank0 only - so only rank0 HomeDir value is relavent */
I think a good policy is to minimize system calls to exactly where and when they are needed.
   Barry
> And what about -options_file?  It also uses MPI_Bcast and is vulnerable
> to the same bugs.  What about DMDAGetLogicalCoordinate (an insane
> function that should be deleted) or DMPlexDistribute, which also call
> MPI_Bcast?
> Alternative is to have configure detect BG/Q and warn loudly that the
> user should set PAMID_COLLECTIVES=0 due to known bugs (all I really want
> for Christmas is for IBM to have a public bug tracker we can reference)
> and then have PetscInitialize check and warn again in case it is not
> set.
>>   We sure as hell shouldn’t have a product that for each new user on
>>   BG requires them to try to use PETSc, have it fail, debug the
>>   problem, like it is now!
> Agreed, this is unacceptable.
