[petsc-dev] BG hang still broken in petsc-maint!
Jed Brown
jedbrown at mcs.anl.gov
Wed Dec 18 17:38:56 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> I never said “ignore” the files. I said error out if the files
> exist or somewhat passes a file name down.
Okay, now they wait in the queue for a week and then the job crashes
first thing. We should be consistent independent of the number of
processes. Error consistently if we must.
> Yes erroring out is a bit annoying but much better than hangs.
Anything is better than hanging.
> I also question why some system calls are made on all processes but only used on one, for example
> if (!flag) {
> ierr = PetscGetHomeDirectory(pfile,PETSC_MAX_PATH_LEN-16);CHKERRQ(ierr);
> /* PetscOptionsInsertFile() does a fopen() on rank0 only - so only rank0 HomeDir value is relavent */
> I think a good policy is to minimize system calls to exactly where and when they are needed.
Agreed.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131218/ea6567db/attachment.sig>
