[petsc-dev] BG hang still broken in petsc-maint!
Jed Brown
jedbrown at mcs.anl.gov
Wed Dec 18 15:17:20 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> We’ve had this discussion before and wasted too much time on it. On
> the BG just don’t allow the damn loading of options for files for
> large runs, say greater than 128 nodes
If we're going to ignore the files, we should generate a loud warning at
configure time and then *always* ignore the files. Ignoring only on
large runs sets people up to do a small trial run and then launch their
expensive job, only to find that it ignored their options.
And what about -options_file? It also uses MPI_Bcast and is vulnerable
to the same bugs. What about DMDAGetLogicalCoordinate (an insane
function that should be deleted) or DMPlexDistribute, which also call
MPI_Bcast?
Alternative is to have configure detect BG/Q and warn loudly that the
user should set PAMID_COLLECTIVES=0 due to known bugs (all I really want
for Christmas is for IBM to have a public bug tracker we can reference)
and then have PetscInitialize check and warn again in case it is not
set.
> We sure as hell shouldn’t have a product that for each new user on
> BG requires them to try to use PETSc, have it fail, debug the
> problem, like it is now!
Agreed, this is unacceptable.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131218/fad133ab/attachment.sig>
