[petsc-dev] [tao-comments #191525] PetscNewLog signature change
Fri Dec 13 14:24:25 CST 2013
On Fri, 13 Dec 2013, Geoffrey Irving wrote:
> On Thu, Dec 12, 2013 at 2:06 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Thu, 12 Dec 2013, Lisandro Dalcin wrote:
> >> On 12 December 2013 18:03, Todd Munson <tmunson at mcs.anl.gov> wrote:
> >> > The idea is to distribute TAO with PETSc and treat it like any other set of PETSc solves.
> >> > All the TaoLog (or TaoNewLog) macros should go away in my opinion and be replace with
> >> > the correct PETSc equivalents.
> >> > Jason?
> >> > Todd.
> >> Not sure if you guys care about previous PETSc releases, but #define
> >> TaoNew[Log] would ease supporting petsc-3.4 in the next TAO release.
> > There won't be a next [standalone] tao release. It will be part of
> > petsc-3.5.
> > And I'm not sure if maintaining a separate tao_version.h makes sense.
> > And there will be a minimal changing of adapting the makefiles to to
> > this new mode [if one needs to maintain comatibility with
> > both petsc-3.4+tao-2.2 and petsc-3.5/tao].
> > You can check the current state of this migration at 'balay/tao-to-petsc' branch.
> That's awesome.  To confirm: I should just merge balay/tao-to-petsc
> into the irving/hollow branch of petsc that I'm using to track the new
> features I need for my simulator development?   I.e., is that branch
> stable enough to track with repeated merges?
Hm - it might go through a couple of rebases before getting merged in
- so I won't say its ready for merge into other branches [unless you
can deal with unmerging/merging rebased branches.]
Satish
