[petsc-dev] [tao-comments #191525] PetscNewLog signature change
Geoffrey Irving
irving at naml.us
Fri Dec 13 14:25:08 CST 2013
On Fri, Dec 13, 2013 at 11:49 AM, Geoffrey Irving <irving at naml.us> wrote:
> On Thu, Dec 12, 2013 at 2:06 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Thu, 12 Dec 2013, Lisandro Dalcin wrote:
>>> On 12 December 2013 18:03, Todd Munson <tmunson at mcs.anl.gov> wrote:
>>> > The idea is to distribute TAO with PETSc and treat it like any other set of PETSc solves.
>>> > All the TaoLog (or TaoNewLog) macros should go away in my opinion and be replace with
>>> > the correct PETSc equivalents.
>>> > Jason?
>>> > Todd.
>>> Not sure if you guys care about previous PETSc releases, but #define
>>> TaoNew[Log] would ease supporting petsc-3.4 in the next TAO release.
>> There won't be a next [standalone] tao release. It will be part of
>> petsc-3.5.
>> And I'm not sure if maintaining a separate tao_version.h makes sense.
>> And there will be a minimal changing of adapting the makefiles to to
>> this new mode [if one needs to maintain comatibility with
>> both petsc-3.4+tao-2.2 and petsc-3.5/tao].
>> You can check the current state of this migration at 'balay/tao-to-petsc' branch.
> That's awesome. To confirm: I should just merge balay/tao-to-petsc
> into the irving/hollow branch of petsc that I'm using to track the new
> features I need for my simulator development? I.e., is that branch
> stable enough to track with repeated merges?
In order for me to use tao-to-petsc I need it to be compatible with
master, so I fix it for the PetscNew changes. The updated branch is
irving/tao-to-petsc
Hopefully that can be merged into your tao-to-petsc branch.
Geoffrey
