[petsc-dev] [tao-comments #191525] PetscNewLog signature change
Geoffrey Irving irving at naml.us
Fri Dec 13 13:49:48 CST 2013
On Thu, Dec 12, 2013 at 2:06 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 12 Dec 2013, Lisandro Dalcin wrote:
>> On 12 December 2013 18:03, Todd Munson <tmunson at mcs.anl.gov> wrote:
>> > The idea is to distribute TAO with PETSc and treat it like any other set of PETSc solves.
>> > All the TaoLog (or TaoNewLog) macros should go away in my opinion and be replace with
>> > the correct PETSc equivalents.
>> > Jason?
>> > Todd.
>> Not sure if you guys care about previous PETSc releases, but #define
>> TaoNew[Log] would ease supporting petsc-3.4 in the next TAO release.
> There won't be a next [standalone] tao release. It will be part of
> petsc-3.5.
> And I'm not sure if maintaining a separate tao_version.h makes sense.
> And there will be a minimal changing of adapting the makefiles to to
> this new mode [if one needs to maintain comatibility with
> both petsc-3.4+tao-2.2 and petsc-3.5/tao].
> You can check the current state of this migration at 'balay/tao-to-petsc' branch.
That's awesome.  To confirm: I should just merge balay/tao-to-petsc
into the irving/hollow branch of petsc that I'm using to track the new
features I need for my simulator development?   I.e., is that branch
stable enough to track with repeated merges?
Geoffrey
