[petsc-dev] [tao-comments #191525] PetscNewLog signature change
    Lisandro Dalcin
    dalcinl at gmail.com
    Thu Dec 12 16:45:11 CST 2013
On 12 December 2013 19:06, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 12 Dec 2013, Lisandro Dalcin wrote:
>> On 12 December 2013 18:03, Todd Munson <tmunson at mcs.anl.gov> wrote:
>> > The idea is to distribute TAO with PETSc and treat it like any other set of PETSc solves.
>> > All the TaoLog (or TaoNewLog) macros should go away in my opinion and be replace with
>> > the correct PETSc equivalents.
>> > Jason?
>> > Todd.
>> Not sure if you guys care about previous PETSc releases, but #define
>> TaoNew[Log] would ease supporting petsc-3.4 in the next TAO release.
> There won't be a next [standalone] tao release. It will be part of
> petsc-3.5.
Oh! I didn't know... Very good news....
> And I'm not sure if maintaining a separate tao_version.h makes sense.
Probably not....
> And there will be a minimal changing of adapting the makefiles to to
> this new mode [if one needs to maintain comatibility with
> both petsc-3.4+tao-2.2 and petsc-3.5/tao].
> You can check the current state of this migration at 'balay/tao-to-petsc' branch.
I guess this should doable.
>> In PetIGA, I'm currently supporting petsc-3.3, petsc-3.4 and master.
> Does PetIGA also use tao [multiple versions?]
No, PetIGA does not depend on TAO. I was trying to point out that
supporting older PETSc releases is doable.
Lisandro Dalcin
CIMEC (UNL/CONICET)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1016)
Tel/Fax: +54-342-4511169
