[petsc-dev] [tao-comments #191525] PetscNewLog signature change
Satish Balay
balay at mcs.anl.gov
Thu Dec 12 16:06:14 CST 2013
On Thu, 12 Dec 2013, Lisandro Dalcin wrote:
> On 12 December 2013 18:03, Todd Munson <tmunson at mcs.anl.gov> wrote:
> > The idea is to distribute TAO with PETSc and treat it like any other set of PETSc solves.
> > All the TaoLog (or TaoNewLog) macros should go away in my opinion and be replace with
> > the correct PETSc equivalents.
> > Jason?
> > Todd.
> Not sure if you guys care about previous PETSc releases, but #define
> TaoNew[Log] would ease supporting petsc-3.4 in the next TAO release.
There won't be a next [standalone] tao release. It will be part of
petsc-3.5.
And I'm not sure if maintaining a separate tao_version.h makes sense.
And there will be a minimal changing of adapting the makefiles to to
this new mode [if one needs to maintain comatibility with
both petsc-3.4+tao-2.2 and petsc-3.5/tao].
You can check the current state of this migration at 'balay/tao-to-petsc' branch.
> In PetIGA, I'm currently supporting petsc-3.3, petsc-3.4 and master.
Does PetIGA also use tao [multiple versions?]
Satish
