[petsc-dev] 2D finite elements in 3D ambient space
Matthew Knepley
knepley at gmail.com
Mon Dec 2 20:45:25 CST 2013
On Mon, Dec 2, 2013 at 8:31 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> [added context]
> >>>> Unfortunately, something more is required for higher order accuracy,
> >>>> since naively the coordinate section itself would have to be higher
> >>>> order, and this would require lots of changes (the equivalent of
> >>>> DMPlexComputeCellGeometry would be called once per quadrature point
> >>>> instead of once per element).
> >>> I have never been convinced that isoperimetric stuff produces enough
> benefit
> >>> for its complication. Polynomials are not good approximators for the
> >>> Jacobian of these transforms. NURBS are so much better.
> >> The value of NURBS is that (a) some coordinate transformations can be
> >> represented exactly and (b) for certain problems, the rest solution can
> >> be represented exactly in the ansatz space. Quadrature error does not
> >> magically vanish.
> > My point is that trying to resolve particular geometry with polynomials
> is
> > very slowly convergent. NURBS are much better. It depends on how
> > complicated your geometry is.
> I thought you were objecting to "the equivalent of
> instead of once per element". If you were in fact agreeing with this,
> and the talk of NURBS was just a tangent, then we are now on the same
> page.
I am agreeing with that. I just hate isoperimetric. Its terrible at really
resolving geometry.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131202/4a4ca4ea/attachment.html>
