[petsc-dev] 2D finite elements in 3D ambient space
Jed Brown
jedbrown at mcs.anl.gov
Mon Dec 2 20:31:00 CST 2013
Matthew Knepley <knepley at gmail.com> writes:
[added context]
>>>> Unfortunately, something more is required for higher order accuracy,
>>>> since naively the coordinate section itself would have to be higher
>>>> order, and this would require lots of changes (the equivalent of
>>>> DMPlexComputeCellGeometry would be called once per quadrature point
>>>> instead of once per element).
>>> I have never been convinced that isoperimetric stuff produces enough benefit
>>> for its complication. Polynomials are not good approximators for the
>>> Jacobian of these transforms. NURBS are so much better.
>> The value of NURBS is that (a) some coordinate transformations can be
>> represented exactly and (b) for certain problems, the rest solution can
>> be represented exactly in the ansatz space. Quadrature error does not
>> magically vanish.
> My point is that trying to resolve particular geometry with polynomials is
> very slowly convergent. NURBS are much better. It depends on how
> complicated your geometry is.
I thought you were objecting to "the equivalent of
instead of once per element". If you were in fact agreeing with this,
and the talk of NURBS was just a tangent, then we are now on the same
page.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131202/9f6eb494/attachment.sig>
