[petsc-dev] 2D finite elements in 3D ambient space
Mon Dec 2 20:19:26 CST 2013
On Mon, Dec 2, 2013 at 8:01 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> Unfortunately, something more is required for higher order accuracy,
> >> since naively the coordinate section itself would have to be higher
> >> order, and this would require lots of changes (the equivalent of
> >> DMPlexComputeCellGeometry would be called once per quadrature point
> >> instead of once per element).
> > I have never been convinced that isoperimetric stuff produces enough
> > benefit for its complication. Polynomials are not good approximators
> > for the Jacobian of these transforms. NURBS are so much better.
> These issues are orthogonal.  If the mapping is not affine, you need
> separate Jacobians at each quadrature point.  Non-affine elements are
> required for high-order accuracy with curved boundaries, and in many
> cases when using quad and hex elements.
I agree that non-affine stuff requires the linearization of the mapping at
each
quadrature. The interface Geoff suggested is the one I have been using for
that. I am fine with it.
> The value of NURBS is that (a) some coordinate transformations can be
> represented exactly and (b) for certain problems, the rest solution can
> be represented exactly in the ansatz space.  Quadrature error does not
> magically vanish.
My point is that trying to resolve particular geometry with polynomials is
very slowly convergent. NURBS are much better. It depends on how
complicated your geometry is.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131202/3defbbc3/attachment.html>
