[petsc-dev] netcdf changeset b8702c0c34ab
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed Sep 12 22:15:42 CDT 2012
His point is that we can't tell it has anything to do with netcdf from the
non-verbose output.
On Sep 12, 2012 10:13 PM, "Satish Balay" <balay at mcs.anl.gov> wrote:
> On Wed, 12 Sep 2012, Sean Farley wrote:
> > Just a quick note from
> > http://petsc.cs.iit.edu/petsc/BuildSystem/rev/b8702c0c34ab
> > "libnetcdf_c++.a not created by the new version?"
> > Correct. Starting with version 4.2 NetCDF has split C++ and Fortran
> > bindings into separate packages. See their announcement for more
> > information,
> > http://www.unidata.ucar.edu/blogs/news/entry/netcdf_4_2_release
> > P.S. Is it that hard to make the first line of the commit message the
> > summary? E.g. "netcdf: update to 4.2.1.1"? In both mercurial and git,
> > the first line of the commit message is used as the subject. This
> > makes reading commits *much* easier.
> Sure - I felt that was a sufficient summary - but you appear to differ on
> that.
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120912/d15876d3/attachment.html>
