[petsc-dev] netcdf changeset b8702c0c34ab
    Satish Balay
    balay at mcs.anl.gov
    Wed Sep 12 22:12:30 CDT 2012
On Wed, 12 Sep 2012, Sean Farley wrote:
> Just a quick note from
> http://petsc.cs.iit.edu/petsc/BuildSystem/rev/b8702c0c34ab
> "libnetcdf_c++.a not created by the new version?"
> Correct. Starting with version 4.2 NetCDF has split C++ and Fortran
> bindings into separate packages. See their announcement for more
> information,
> http://www.unidata.ucar.edu/blogs/news/entry/netcdf_4_2_release
> P.S. Is it that hard to make the first line of the commit message the
> summary? E.g. "netcdf: update to 4.2.1.1"? In both mercurial and git,
> the first line of the commit message is used as the subject. This
> makes reading commits *much* easier.
Sure - I felt that was a sufficient summary - but you appear to differ on that.
Satish
