[petsc-dev] [petsc-maint #136525] implementations of parallel sorting algorithms?
Barry Smith
bsmith at mcs.anl.gov
Fri Oct 19 08:25:30 CDT 2012
On Oct 19, 2012, at 2:28 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Oct 19, 2012 at 2:10 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Developers: I'm in favor of keeping these "projects" in the tracker instead
> of on the project page below, which is more work to edit, harder to
> "comment" on, and that nobody can easily "watch".
> http://www.mcs.anl.gov/petsc/developers/projects.html
> And that list isn't even kept up-to-date.
> https://bitbucket.org/petsc/petsc-dev/changeset/f89b5d9caf313dbe74b74ce0dbdf763f75752679
> Barry, did you do the Apple Framework thing?
Yes, I think so (though it is useless because users need to write non-portable code to use it; thanks to the damn Apple import instead of include business).
> Should we put a link from projects.html to the bitbucket tracker?
I have no objection to completely removing the "projects.html" page and instead having the link in the left-hand-side going straight to your tracker. In fact, I would like to see that page removed
Barry
I can see Sean dancing in his PJs right now, he is so happy that I've agreed to something that doesn't just use 1980s style Unix.
