[petsc-dev] [petsc-maint #136525] implementations of parallel sorting algorithms?
Jed Brown
jedbrown at mcs.anl.gov
Fri Oct 19 02:28:35 CDT 2012
On Fri, Oct 19, 2012 at 2:10 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Developers: I'm in favor of keeping these "projects" in the tracker instead
> of on the project page below, which is more work to edit, harder to
> "comment" on, and that nobody can easily "watch".
> http://www.mcs.anl.gov/petsc/developers/projects.html
And that list isn't even kept up-to-date.
https://bitbucket.org/petsc/petsc-dev/changeset/f89b5d9caf313dbe74b74ce0dbdf763f75752679
Barry, did you do the Apple Framework thing?
Should we put a link from projects.html to the bitbucket tracker?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121019/dc2d1b8f/attachment.html>
