[petsc-dev] [petsc-maint #136525] implementations of parallel sorting algorithms?
Sean Farley
sean at mcs.anl.gov
Fri Oct 19 12:10:19 CDT 2012
On Fri, Oct 19, 2012 at 8:25 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Oct 19, 2012, at 2:28 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Fri, Oct 19, 2012 at 2:10 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Developers: I'm in favor of keeping these "projects" in the tracker instead
>> of on the project page below, which is more work to edit, harder to
>> "comment" on, and that nobody can easily "watch".
>> http://www.mcs.anl.gov/petsc/developers/projects.html
>> And that list isn't even kept up-to-date.
>> https://bitbucket.org/petsc/petsc-dev/changeset/f89b5d9caf313dbe74b74ce0dbdf763f75752679
>> Barry, did you do the Apple Framework thing?
> Yes, I think so (though it is useless because users need to write non-portable code to use it; thanks to the damn Apple import instead of include business).
>> Should we put a link from projects.html to the bitbucket tracker?
> I have no objection to completely removing the "projects.html" page and instead having the link in the left-hand-side going straight to your tracker. In fact, I would like to see that page removed
> Barry
> I can see Sean dancing in his PJs right now, he is so happy that I've agreed to something that doesn't just use 1980s style Unix.
http://maddiewood.com/wp-content/uploads/2012/04/dancing-in-pjs-poster.jpg
