[petsc-dev] [petsc-users] MatTransposeMatMult ends up with an MPI error
Wed Oct 17 16:31:29 CDT 2012
On Oct 17, 2012, at 3:35 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Wed, Oct 17, 2012 at 3:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Oct 17, 2012, at 3:23 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > No. The problem is that Open MPI does not fix their critical bugs, they just downgrade them from "blocker" so they can make a release. It's not easy for them to fix because they need to refactor some lower level protocols.
>    Ahh yes. It is nice to have a sophisticated bug tracking system; it makes it easy to relabel bugs with a single click to avoid doing work. We should add this to PETSc :-)
> At least there is a place I can refer people to the open tickets. A dead thread on a mailing list is much worse evidence of a known bug.
> Good thing we have a ticket people can watch to get news of the work-around. ;-)
> https://bitbucket.org/petsc/petsc-dev/issue/9/implement-petscsf-without-one-sided
>    BTW: Shouldn't you have configure detect this issue and turnoff the building of SF or print appropriate error messages so we don't get these confusing petsc-maint that only you can understand?
> We can't detect it without either (a) running MPI code or (b) blacklisting Open MPI.
  Well if it always happens with OpenMPI then you should just turn off one-sided for Open MPI?
   Barry
