[petsc-dev] [petsc-users] MatTransposeMatMult ends up with an MPI error
Jed Brown
jedbrown at mcs.anl.gov
Wed Oct 17 16:43:39 CDT 2012
On Wed, Oct 17, 2012 at 4:31 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Well if it always happens with OpenMPI then you should just turn off
> one-sided for Open MPI?
Sure, but we have to remember to remove the check when/if they fix the bug.
It's kinda like deciding whether something will work based on the current
username or name of a compiler. It's not what we usually do which is to
test for features.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121017/fa4aa11a/attachment.html>
