[petsc-dev] PCRedundant problem
    Hong Zhang
    hzhang at mcs.anl.gov
    Mon Oct 15 16:37:32 CDT 2012
Stefano :
> Hong, INTERLACED is the default since
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/67df4fdba5bd
> See also http://petsc.cs.iit.edu/petsc/petsc-dev/rev/c04222d17a3d
Hmm, you are correct :-(
> Hong, in petsc-dev, default is interlaced. I ran some tests, I got malloc
>> errors when inserting mat values using subcomm of contiguous type. I think
>> that PCRedundant with PETSC_SUBCOMM_CONTIGUOUS is buggy.
PETSC_SUBCOMM_CONTIGUOUS was introduced for  multiprocessor bjacobi
preconditioner,
which has not been used/tested in other situations, likely causes problems.
Can you send us a stand-alone code that reproduces the malloc errors?
Hong
>> 2012/10/15 Hong Zhang <hzhang at mcs.anl.gov>
>>> Stefano :
>>>> is it possible to use PCRedundant with PETSC_SUBCOMM_CONTIGUOUS as
>>>> subcomm type?
>>> I think "PETSC_SUBCOMM_CONTIGUOUS" is the default for PCRedundant.
>>> Hong
>> Stefano
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121015/175c7988/attachment.html>
