[petsc-dev] PCRedundant problem
Stefano Zampini
stefano.zampini at gmail.com
Mon Oct 15 15:38:42 CDT 2012
Hong, INTERLACED is the default since
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/67df4fdba5bd
See also http://petsc.cs.iit.edu/petsc/petsc-dev/rev/c04222d17a3d
2012/10/15 Stefano Zampini <stefano.zampini at gmail.com>
> Hong, in petsc-dev, default is interlaced. I ran some tests, I got malloc
> errors when inserting mat values using subcomm of contiguous type. I think
> that PCRedundant with PETSC_SUBCOMM_CONTIGUOUS is buggy.
> 2012/10/15 Hong Zhang <hzhang at mcs.anl.gov>
>> Stefano :
>>> is it possible to use PCRedundant with PETSC_SUBCOMM_CONTIGUOUS as
>>> subcomm type?
>> I think "PETSC_SUBCOMM_CONTIGUOUS" is the default for PCRedundant.
>> Hong
> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121015/02e111bc/attachment.html>
