[petsc-dev] PCRedundant problem
Hong Zhang
hzhang at mcs.anl.gov
Tue Oct 16 09:01:50 CDT 2012
Stefano,
Checking PCRedundant, I see that current PCRedundant is hard-coded using
PETSC_SUBCOMM_INTERLACED
which 'avoid data scattering from subcomm back to original comm'
See ~petsc/src/sys/objects/subcomm.c - PetscSubcommCreate_interlaced()
Unless you write a new implementation, PETSC_SUBCOMM_CONTIGUOUS cannot be
used
for PCRedundant.
Hong
On Mon, Oct 15, 2012 at 4:37 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Stefano :
>> Hong, INTERLACED is the default since
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/67df4fdba5bd
>> See also http://petsc.cs.iit.edu/petsc/petsc-dev/rev/c04222d17a3d
> Hmm, you are correct :-(
>> Hong, in petsc-dev, default is interlaced. I ran some tests, I got malloc
>>> errors when inserting mat values using subcomm of contiguous type. I think
>>> that PCRedundant with PETSC_SUBCOMM_CONTIGUOUS is buggy.
> PETSC_SUBCOMM_CONTIGUOUS was introduced for multiprocessor bjacobi
> preconditioner,
> which has not been used/tested in other situations, likely causes problems.
> Can you send us a stand-alone code that reproduces the malloc errors?
> Hong
>>> 2012/10/15 Hong Zhang <hzhang at mcs.anl.gov>
>>>> Stefano :
>>>>> is it possible to use PCRedundant with PETSC_SUBCOMM_CONTIGUOUS as
>>>>> subcomm type?
>>>> I think "PETSC_SUBCOMM_CONTIGUOUS" is the default for PCRedundant.
>>>> Hong
>>> Stefano
>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121016/db1bf8ee/attachment.html>
