[petsc-dev] dates of last change on PETSc web pages
Tue Mar 20 19:48:15 CDT 2012
On Tue, 20 Mar 2012, Sean Farley wrote:
> > 1. It apeared that you were fixing sources that go primarily to the
> > website.  [So I was looking at modifying the tarball that goes into
> > "snapshots". All docs in tarball and snapshots should have the date of
> > the taball generation.]
> I actually don't need to modify each page because this changeset gave me a
> better idea which will hopefully combine the best of both worlds.
>  2. I was iterating over few test - which are not yet complete.
> > 3. my push was before ISO-8601 sugestion - thats an easy enough change.
> > 4. I could move the location of the date code into the <body> . But
> > now since you have a better fix - I'll revert his change so you can
> > push the better fix.
> Ok, if you're going to revert then I'll wait to push until then.
reverted now.
satish
