[petsc-dev] dates of last change on PETSc web pages
Sean Farley
sean at mcs.anl.gov
Tue Mar 20 18:38:01 CDT 2012
> 1. It apeared that you were fixing sources that go primarily to the
> website. [So I was looking at modifying the tarball that goes into
> "snapshots". All docs in tarball and snapshots should have the date of
> the taball generation.]
I actually don't need to modify each page because this changeset gave me a
better idea which will hopefully combine the best of both worlds.
2. I was iterating over few test - which are not yet complete.
> 3. my push was before ISO-8601 sugestion - thats an easy enough change.
> 4. I could move the location of the date code into the <body> . But
> now since you have a better fix - I'll revert his change so you can
> push the better fix.
Ok, if you're going to revert then I'll wait to push until then.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120320/54cb8b9e/attachment.html>
