[petsc-dev] dates of last change on PETSc web pages
Tue Mar 20 19:05:37 CDT 2012
On Mar 20, 2012, at 6:34 PM, Satish Balay wrote:
> 1. It apeared that you were fixing sources that go primarily to the
> website.  [So I was looking at modifying the tarball that goes into
> "snapshots". All docs in tarball and snapshots should have the date of
> the taball generation.]
   Satish,
     I don't want the dates being put in when the tarball is created (for snapshots or anywhere else) I want them to go in when each manual page is made during the make docs process.
     The reason is that we ALWAYS want dates in the manual pages, not just sometime in them (those without the dates will be the hardest to eradicate from the web).
   Barry
> 2. I was iterating over few test - which are not yet complete.
> 3. my push was before ISO-8601 sugestion - thats an easy enough change.
> 4. I could move the location of the date code into the <body> . But
> now since you have a better fix - I'll revert his change so you can
> push the better fix.
> satish
> On Tue, 20 Mar 2012, Sean Farley wrote:
>> So, Satish, the reason I responded to this thread was so that you didn't
>> add something silly like this:
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/84867464b28c
>> 1) This isn't even correct. You added a <div> element to the <head> element
>> which is not allowed in any html version
>> 2) This mucks up the styles defined in the css sheet and pushes the rest of
>> the elements down (as opposed to floating)
>> 3) This isn't from the latest mercurial revision
>> 4) This isn't ISO-8601
>> Is there any particular reason you didn't follow this thread?
