[petsc-dev] dates of last change on PETSc web pages
Satish Balay
balay at mcs.anl.gov
Tue Mar 20 18:34:42 CDT 2012
1. It apeared that you were fixing sources that go primarily to the
website. [So I was looking at modifying the tarball that goes into
"snapshots". All docs in tarball and snapshots should have the date of
the taball generation.]
2. I was iterating over few test - which are not yet complete.
3. my push was before ISO-8601 sugestion - thats an easy enough change.
4. I could move the location of the date code into the <body> . But
now since you have a better fix - I'll revert his change so you can
push the better fix.
satish
On Tue, 20 Mar 2012, Sean Farley wrote:
> So, Satish, the reason I responded to this thread was so that you didn't
> add something silly like this:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/84867464b28c
> 1) This isn't even correct. You added a <div> element to the <head> element
> which is not allowed in any html version
> 2) This mucks up the styles defined in the css sheet and pushes the rest of
> the elements down (as opposed to floating)
> 3) This isn't from the latest mercurial revision
> 4) This isn't ISO-8601
> Is there any particular reason you didn't follow this thread?
