[petsc-dev] dates of last change on PETSc web pages
Sean Farley
sean at mcs.anl.gov
Tue Mar 20 18:17:07 CDT 2012
So, Satish, the reason I responded to this thread was so that you didn't
add something silly like this:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/84867464b28c
1) This isn't even correct. You added a <div> element to the <head> element
which is not allowed in any html version
2) This mucks up the styles defined in the css sheet and pushes the rest of
the elements down (as opposed to floating)
3) This isn't from the latest mercurial revision
4) This isn't ISO-8601
Is there any particular reason you didn't follow this thread?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120320/6da07058/attachment.html>
